Results 1 to 15 of 21
    systemlinux's Avatar
    Oct 2018
    CDK
    Default VIN ISN CAS3 BMW
    Can a colleague help me with these files?
    I need to copy the VIN and ISN from the old flash to the new flash
    Flash_old has bad sectors, I can't clone it with XPROG.
    Thanks + Reputation to deliver for the collaboration
    doctore's Avatar
    Nov 2015
    Colorado Denver
    post eprom from cas 4kb, not flash
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  3. The Following User Says Thank You to doctore For This Useful Post:
    systemlinux (26th May, 2020)
    Oct 2018
    CDK
    Copy EEPROM to both CAS3 and the vehicle does not recognize the remote.
    With the old CAS the vehicle is dead and with the new CAS the lights are centralized, but it is immobilized.
    so I think there must be VIN and ISN in the flash too
    ricked's Avatar
    Apr 2016
    Europe
    just post old and new eeprom files like requested...
  6. The Following User Says Thank You to ricked For This Useful Post:
    not work if witing only eep becouse both probably have diffrent sw isn is in eep how writing boys
    or you have hw diffrent quartz one metal - old and one brown -new
  8. The Following User Says Thank You to GT-INFO For This Useful Post:
  9. #6
    droidwayne65's Avatar
    Aug 2015
    North America
    How about posting all files from each unit? Folks would have a better idea of what's going on.
    <---- Coin of the Realm.
  10. The Following User Says Thank You to droidwayne65 For This Useful Post:
  11. #7
    Oct 2018
    CDK
    a thousand apologies for the delay.
    I upload backup of each CAS
  12. #8
    doctore's Avatar
    Nov 2015
    Colorado Denver
    read isn from ecu
  13. The Following User Says Thank You to doctore For This Useful Post:
  14. #9
    Oct 2018
    CDK
    Quote Originally Posted by doctore View Post
    read isn from ecu
    The ISN in which memory is the ecu? Flash, Micro or EEprom?
    to upload the corresponding file
  15. #10
    doctore's Avatar
    Nov 2015
    Colorado Denver
    I dont no what car you have, how you think that i can help you in this moment, post picture from ecu or full bdm
  16. #11
    Oct 2018
    CDK
    Attached backup ECU BOSCH 0 261 S04 115 made with KTAG
  17. #12
    bearheroes's Avatar
    Dec 2011
    If you ever decide what you want to do inform...eep is not enough to start car. You must transfer flash also. Vin isn and all data are in eeprom.
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  18. #13
    Oct 2018
    CDK
    XPROG detected bad sectors on the CAS3_OLD flash and does not let the flash copy to the CAS3_NEW.
    The idea is to transfer the necessary info to the new flash, in order to copy it without problems.
  19. #14
    doctore's Avatar
    Nov 2015
    Colorado Denver
    erase mcu flash with xprog , and then write new flash.
  20. #15
    Oct 2018
    CDK
    I understand that there is a BMW editor or explorer software, which serves to synchronize DME with CAS3.
