Results 1 to 8 of 8
    Oct 2019
    Italia
    Default Ducato SW DPF NO WORL HELP PLEASE!
    Hi friends who can help me to eliminate the dpf on this duchy. I worked the file with a vault but after 50km it goes in inert mode. With warning light, with DTC 1254 PARTICULAR FILTER
    Can anyone help me with a solution that works well.
    ID:
    Bosch
    EDC16C39
    1037515041
    EURO4
    Jul 2012
    the two files look different .. did you read and write the same file?
    Oct 2019
    Italia
    Ori ducato read obd.
    ducato sw dpf not work read bdm mod change rsa zone
    Jul 2012
    your fap solution is incorrect
    Oct 2019
    Italia
    You have solution tested??
    Jul 2012
    Quote Originally Posted by Fronzies View Post
    your inbox is full
    Oct 2019
    Italia
    Post file box is ok now
    Oct 2019
    Italia
    no one has the solution that works well? or the clogging and setting up bit can help me
