Results 1 to 12 of 12
    Nov 2015
    Default PSA S2000 PEUG 406 IMMO OFF
    HI may you help me immo off for 406 peug with 95080
    ecu part number 9643786480 sagem
    s2000-1
    1.8ltr
    try to take off eeprom 95080 anq start
    speedy100's Avatar
    Athens
    Here Immo Off.
    Cut pins F3, F4 inside the ECU.
    Please report back.
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  4. The Following User Says Thank You to speedy100 For This Useful Post:
    innochambs (25th May, 2020)
    Nov 2015
    hi thank you the car starts but rpm not going above 3000revs
    speedy100's Avatar
    Athens
    Quote Originally Posted by innochambs View Post
    With my file?
    Nov 2015
    you did not give me any file u just said i should try to remove eeprom if u have the file can u please help
    speedy100's Avatar
    Athens
    Haha,
    Look at post #3 and Your inbox for PM.
    Nov 2015
    Okay thank u let me try now
    Sent from my COR-L29 using Tapatalk
  10. #9
    Nov 2015
    your file has worked 100% thank u
  11. The Following User Says Thank You to innochambs For This Useful Post:
    speedy100 (25th May, 2020)
  12. #10
    bluedid's Avatar
    Mar 2009
    Greece
    please can anybody send me that file I have the same problem !!!
    thank you
  13. #11
    Mar 2022
    Hello friend can you send me the password. Thanks in advance
  14. #12
    Dec 2018
    Quote Originally Posted by Ecucarespj View Post
    Post ori eeprom from car
  15. The Following User Says Thank You to elektronik325 For This Useful Post:
    rafal (7th February, 2023)
