Results 1 to 11 of 11
    Oct 2015
    Default Programme key for Renault Kangoo 2019
    hello everyone I tried to program a second key for renault kangoo 2019 with several tools (ZEDFULL, x300 DP PLUS, T-CODE) but no I did not succeed it does not come read generate the pin code there is a solution to read it via OBD or on the table read an electric component
    Dec 2016
    Quote Originally Posted by salim74 View Post
    Renault Ecu Tool made keys for Master 3 Kangoo 2 , they use same BCM for all years
    Aug 2019
    Bucharest Romania
    Have you tried Renolink? UCH Kangoo2, Master3, Traffic2 Ph3.
    Dec 2016
    Quote Originally Posted by andreia67 View Post
    i never use this tool for key programming ( just for diag ), on this cars , x100pad2 & R.E.T work fine
    Jun 2020
    mexico
    in mexico for make that key use tool GAMARRA it have a BSI continental and need new key hitag aes 7961m
    topclef's Avatar
    New Renault Kangoo 2019 is not supported by any devices , new algorithm
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  7. The Following User Says Thank You to topclef For This Useful Post:
    p1et (25th June, 2020)
    Dec 2016
    Quote Originally Posted by topclef View Post
    no , i already made key for 2019 Kangoo , RET say 2007 - 2014 , but work for all kangoo , tested .... Maybe 2020 ; too many theft on this models
    Dec 2016
    Quote Originally Posted by keycommerce View Post
    not in France , id46 PCF7947 , maybe not same immo for all the world ?????
  10. #9
    Jun 2020
    mexico
    yes, it can be program even if all key lost, the only uch canīt make is johnson control
  11. #10
    Dec 2016
    OK , they add new BSI after 2019 , 50% of chance to made key !
  12. The Following 2 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    IKEYS (25th June, 2023), p1et (26th June, 2020)
  13. #11
    Jun 2020
    mexico
    do you have a pictrue of the uch to see in mexico one car use that
