Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Mar 2008
    Default Read MC68HC11KA4 with FT2232HL?
    Hello,
    I'll try to read dump from processor MC68HC11KA4, but I dont know if it's ok with my FT2232HL board. I glued the wires, but I don't know exactly how to connect rx, tx and reset on my FT2232HL board.
    Can I find the code by serial? Thanks
    VWZ2Z2A3149940 1J0035152E
    carradio2001's Avatar
    Nov 2009
    France
    You choose oscillator the correct frequency ? In software the same as on board ?
    Carradio2001.
  3. The Following User Says Thank You to carradio2001 For This Useful Post:
    zappaf (26th May, 2020)
    Mar 2008
    I dont have (I dont find it) oscilator on FT2232HL board. On Program I choose 8.664MHz. RX and TX it's ok on vwz2z2 board. RST the same. But I must connect 5V on pin 1? And conect radio on 12V?
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Hy,
    Try to change Rx pin with Tx
    I see this situation when i read Nec procesor
    Regrads
  6. The Following User Says Thank You to catalinosonesti For This Useful Post:
  7. #5
    Mar 2008
    Nothing.
    It's correct? Like in picture.
  8. #6
    Nov 2009
    France
    Quote Originally Posted by zappaf View Post
    Don't forget MODA and MODB. Both on GND.
  9. The Following User Says Thank You to carradio2001 For This Useful Post:
  10. #7
    Mar 2008
    Pin 59 and 60? Both are ground (-) on FT2232 board and radio. It's connect ok (on picture)?
  11. #8
    Mar 2008
    Nobody? .
  12. #9
    Nov 2009
    France
    Nobody? .
    What software did use for that MCU ?
    Carradio2001.
  13. The Following User Says Thank You to carradio2001 For This Useful Post:
    zappaf (30th May, 2020)
  14. #10
    Mar 2008
    Motorola cracker.
  15. #11
    Nov 2009
    France
    Motorola cracker.
    Then must be easy. Connect Moda A and Moda B at GND, Connect Rx from interface to Tx from MCU, Tx from interface to Rx from MCU, Reset at Reset. You put power on the radio but not ON.
    Seelct correct COM to your interface and I recommend to change Quartz ...put 8MHz and select 8MHz . And Boot MCU. And Read MCU after boot successful.
    Good luck.
    Carradio2001.
  16. The Following 2 Users Say Thank You to carradio2001 For This Useful Post:
    catalinosonesti (30th May, 2020), zappaf (30th May, 2020)
  17. #12
    Mar 2008
    connect.jpg[/QUOTE]
    I'll try to change rx to tx.
    Thanks.
  18. #13
    Mar 2008
    I changed rx with tx, but no succes.
    But I have a question; with 59+60 (modA modB)connect together on ground the radio not start (no light, no SAFE), only little red led flashing. Without pin 59+60 connect together, when I put 12V radio light and SAFE (when button PWR push). I made something wrong? Does the radio have to display something when both pins (59+60) are connected to gnd?
  19. #14
    Nov 2009
    France
    When put moda and modb to gnd input the MCU in boot mode.
    Carradio2001.
  20. The Following User Says Thank You to carradio2001 For This Useful Post:
    zappaf (1st June, 2020)
  21. #15
    Mar 2008
    No succes. I think I'm not connecting the pins correctly on the board (RX, TX and RST)
