Results 1 to 11 of 11
    Mar 2017
    Default Vvdi prog imm100.01
    Need help
    I have immo box lancia Libra 2003year AKL
    I try to read 0D66J like in description in vvdi prog but no luck....(imobox fiat 0D66J)
    So I need help how to read...I have adapter for hc05 but I think that is not same or I am wrong.... no.problem for desoldering...
    I also have prog....
    Any advice please thx!
    vialli's Avatar
    Aug 2018
    Romania
    If you have this is need to desoldering, the picture is from Tango
  3. The Following User Says Thank You to vialli For This Useful Post:
    immoneard (26th May, 2020)
    Mar 2017
    Yes I have this....
    So I need to desolder and ?
    p1et's Avatar
    Oct 2013
    I think UPA or ETL can read this
    May 2014
    vvdiprog can read this without any problem. only with threads
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by alefabi2006 View Post
    What do you mean?
    May 2014
    only by soldering 5 wires on the board. equal to UPA
  9. The Following User Says Thank You to alefabi2006 For This Useful Post:
    p1et (26th May, 2020)
  10. #8
    Feb 2011
    i read this immo vvdi prog
  11. The Following 2 Users Say Thank You to waldigsi For This Useful Post:
    doctore (27th May, 2020), p1et (27th May, 2020)
  12. #9
    Mar 2017
    Quote Originally Posted by waldigsi View Post
    I try with this "option" and nothing
  13. #10
    Mar 2017
    I get this
  14. #11
    Mar 2017
    Read ok with 12mhz osc
    After successful read ,,make id48 with Fvdi2018,?, but did not write new key to Motorola back...with effi take code from eeprom...and with SBB program key with option lybra 98 to 06...maybe will help this info to somebody.
  15. The Following 4 Users Say Thank You to hitechservis For This Useful Post:
    doctore (27th May, 2020), IKEYS (3rd July, 2023), immoneard (27th May, 2020), p1et (27th May, 2020)
