i don't see vin or security in this dump,which module did you read it from?
via OBD , using carprog , the original file extension is RPT but i changed it to BIN
form witch module? as far as i remember you need to dump instrument panel/ecu/display to get pin
I find the radio the easiest way to retrieve pin on these,you're posted file doesn't look good,it has the same data repeated from start to finish
in your dump not VIN,not PIN.is bad read.
Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
i will try again then i will let you know , thanks again
