Results 1 to 5 of 5
    Default MERCEDES EZS A9069003403
    Hi guys,
    Is someone could help me, i need ezs flash file because i think it's corrupt
    Key don't turn on EZS but remote work
    ref A9069003403 from mercedes sprinter.
    Thank you
    right here right now
    Desolder ignition barrel from ezs and check the micro switch on pcb for continuity with a multimeter,I've seen these switches fail several times,I think in you're case it's more likely to be this as if the file was corrupt the central locking wouldn't work.
    Sent from my SM-G950F using Tapatalk
    I’m sure it’s file pb I tried to read first with my laptop and r260 and i missed a file (Mshflxgd.ocx). I tried a lot of things and change laptop. I read file and correct mileage. Then I put back ezs and key didn’t turned. If someone could check my files please?
    Thank you
    i have a used ezs from sprinter is someone could adapt my datas (password and keys) to the file from new ezs?
    Thanx for help
    Solved it was ESL pb
