Results 1 to 4 of 4
    Jan 2019
    Somewhere between Continents
    Default Question About UPA S Prog Soft V2.2
    Hello guys, so i was hoping someone could help me out a bit in some questions i have...
    I was able to get the "New" UPA Soft 2.2 with a license. (at least it opens without UPA connected and shows its registered to 1 device)
    But i only have Upa Clone 1.3.
    If i connect with this software, will it work?
    Could this be Blocked by some reason if i try this new software?
    If this works, would i get any benefits in using it?
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
    Sep 2019
    No , it will not work. Software licence key is created accordingly to a upa usb device Id only after purchase of original one.
    So if you connect your device with the software , it will not detect your device...
    Sent from my Redmi Note 6 Pro using Tapatalk
  3. The Following User Says Thank You to armstrong1690 For This Useful Post:
    boxsport (27th May, 2020)
    Sep 2019
    And also upa hardware is upgraded now. You have old hardware (chinese version)
  5. The Following User Says Thank You to armstrong1690 For This Useful Post:
  6. #4
    Jan 2019
    Quote Originally Posted by armstrong1690 View Post
    Thanks. I know that it has some kind of hardware lock, but i was kind of hoping some guru friend here at DK could sort that out...
    Anyway, if i connect to new soft version to test, it shouldn't create problems, right?...
    And regarding the new hardware, do you know if anyone has any info and/or schematics for the new pcb board?
