Results 1 to 5 of 5
    Question Audi A3 8V 5Q0959655N - Internal Control Module Memory Checksum Error B2000
    Hello mates,
    I have an Audi A3 8V year 2014 with problem on airbag module.
    Car's battery went flat during lockdown and after a very long start attempt (due battery low voltage) airbag module had error inside about Checksum.
    Module is 5Q0959655N.
    Inside two B2000 errors.
    I read SPC560 and make a crash clear file.
    After this one of two B2000 error was resetted.
    But no way to reset another one.
    I tried to reprogram control unit with frf file too.
    Attacched original corrupted file and clear that I make.
    Can someone help me, please ?
    Thank you
    Bests
    Nov 2016
    Enniskillen
    Hello
    Did you get fix it or still you have problem with it?
    I have same fault B2000 and tried clear crash data and still the same.
    SPC560P50
    Can someone repair data with errror B2000 - Internal Control Module Memory Checksum Error ?
    Arek
    Mate I changed the airbag ecu to solve the problem!
    Nov 2016
    Enniskillen
    Quote Originally Posted by paskuale View Post
    Hello
    Did you changed on new one and done coding or changed on second hand and transfer data to donor ?
    Arek
    Change with new one and done online coding and cp removal.
