Results 1 to 8 of 8
    Sep 2016
    Default AUDI A8 4.2 TDI stage 1 check
    Hello,could someone check this remap from Audi A8, 4.2 TDI? sometimes by "heavy foot"driving it goes aprox. by 3300-3500 RPM to limp mode with VCDS fault P1063 - 001 (Fuel Pressure Regulation: Control Range Not Reached) and P300A - 003 (Diesel Particle Filter, Differential Pressure Sensor - Implausible Signal). Before the remap was all ok. Thank you
    tunelab's Avatar
    Feb 2019
    also post your original file
    Sep 2016
    here is ori file
    tunelab's Avatar
    Feb 2019
    dont use this file its danger
    by the way this car can be much much better tune and safe
  5. The Following User Says Thank You to tunelab For This Useful Post:
    tommyno18 (28th May, 2020)
    Sep 2016
    The sad fact is, that i bought the remap from offered file service on the UK web page (A*E). After confrontation with the tuner he said, he made his work good and the problem is in car and i should do my job now with mechanical issues. So i get this "great" support from the remaper....
    Oct 2018
    Bad Tuning... if you need good and safe Tuning Files you can contact us
  8. The Following User Says Thank You to TSC2010 For This Useful Post:
    tommyno18 (29th May, 2020)
  9. #7
    Sep 2013
    ES
    personally, a lot of injection time , turbo,nm and pressure
  10. The Following User Says Thank You to Manuelgb For This Useful Post:
  11. #8
    Sep 2013
    ES
    brother here you are, it has less power, but I think you like it more, report the change. pass mp
  12. The Following User Says Thank You to Manuelgb For This Useful Post:
    tommyno18 (31st May, 2020)
