Smok $$ is the best !!!!
But IN FRANCE PIN CODE IS FREE ( in glove with box manuel , OR 3 € )
for this reason i have not this option , just use my x100 pad pro for read 50% of PIN code AKL ...
Hi guys. Looking to buy pin reader for PSA group in AKL situation. Have Lonsdor which giving lot but not all (with pug407 and some have problem) I want to buy Smok or IO terminal PSA. So here is questions for owners:
- i know Smok reading pins in 2016 cars (F**k) is IO coverage is the same? i mean IO reading PSA cars 2016+?
If yes i will take IO coz i can read and write flash in same module but in Smok it is additional option $$
*thanks for reply
arosta (29th May, 2020)
Smok support Delphi bsi for pin read with slightly bigger coverage as Abritus.
Delphi akl, avdi yes.
Smok needs working key to collected pin.
Smok.jpgRead this, working key needed.
Dont post, if you dont know
I know that better as not removed old description from program box. I can assure you that my knowledge about it is correct.
p1et (29th May, 2020)
continental BSI can be a bugger on Smok
bugger on AVDI also - maybe recent update but i still remove BSI .
(after costing me approx £900 to put right....)
I use udscanonline.com
Best tool for ever!!!
Never let me down.
Delphi, and even on Peugeot 208 2008 2020+!!!
You can adapt ecu, bsi... Seven securised ecu (not ecu motor).
Very very good tool.
And support is also very very good.
You can take it without any risk.
With Tapatalk
Manta1600 (31st May, 2020)
Uds can online is just a joke.it’s very expensive.and you need to have ams paid if you want use your tool.
And for 2500€ for full psa ,he don’t read can bsi.
You can buy a lot of other tool without ams for this price.
Envoyé de mon iPad en utilisant Tapatalk
Ok,
But what tool can resolve problem of remote working after have change vin?
And so on.
It's true little expensive. But it's best for car using uds protocol.
With Tapatalk
