Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: ML 163 trouble
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    Default ML 163 trouble
    Good morning , im in trouble with this W163 , done a new key in position 3 and after no start with all key
    origina too ,read DAS with fvdi but sadly after the disaster.
    the info from the das is key number ------ trasponder programmed = yes
    trasponder interloked = no
    read ori key with zedbull
    pcf7930
    10521163f8d5fde10000000000008002
    Reality of life :
    1: never argue with an idiot they will drag you down to their level and beat you with experienceend
    2: envy is the confession of inferiority
    3: everyone lies
    4: It’s hard to argue with a genius. It’s impossible to argue with an idiot
    5: i love the smell of hypocrisy in the morning ...... moneyseekers ......
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by dariobmw View Post
    pcf7930
    Which tool u used to program key pos-3?
    Sent from my SM-J415F using Tapatalk
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    FVDI why ?
    Reality of life :
    3: everyone lies
    ASCM's Avatar
    Oct 2018
    FVDI why ?
    Which steps u used to make it?
    Try to disconnect battery after that relearn ori key
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    Hu ok , read immo key occuped , 2-7 , prepared with fvdi tag w163 unprogrammed pcf7935
    try first time with the special option creation not work bad pcf programm connecto to obd
    and programmed new unprogrammed , key and after programming start error on dash
    reprogrammed same key same position , and start error gone but no key more work .
    Reality of life :
    3: everyone lies
    doctore's Avatar
    Nov 2015
    Colorado Denver
    fvdi duet this car in minut, fix tag anthena and make key
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    Thanks for reply , but no more work the ori key too ? why ?
    the second pcf done with fvdi tag tool ( prepare is ok ) no work too
    the file is ok ?
    the key ori what number is ?
    Reality of life :
    3: everyone lies
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    yes doctore you are right , done in the same way ( if i remember well ) one year ago same car ,
    pcf new and blade and lock from scrap , done in 10 min ...... this car is bastard !!!!
    Reality of life :
    3: everyone lies
    doctore's Avatar
    Nov 2015
    Colorado Denver
    reset battery and tr again add original key
  10. The Following User Says Thank You to doctore For This Useful Post:
    dariobmw (30th May, 2020)
  11. #10
    Jul 2010
    EU
    or write back original dump to car and see , did original key start car and try to make second key from file whit tango or gambit . i aways use fvdi to read aae eam and make transponder whit tango and car start fine.
  12. The Following 2 Users Say Thank You to iozo For This Useful Post:
    dariobmw (30th May, 2020), p1et (5th January, 2021)
  13. #11
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    thanks for your advice you are very kind , and smart , i will try and soon seport , for now i have left it alone ......
    (sometimr i think some petrol and a lighter solve alot of problem :-))
    Reality of life :
    3: everyone lies
  14. #12
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    Ok this morning detached the battery for 1 hour, no start , try to reprogramm the ori key on the position 2 , no start , let the key with the igniton on
    for 1/2 hour and car start one time then start error , before all this mess ori key ever work perfect , see on the state , key number ------
    trasponde programmed OK trasponder interlocked NO .......
    I see around on forum talk about the rolling code
    key 10521163F8D5FD53
    206BE6D8
    Reality of life :
    3: everyone lies
  15. #13
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    try to put 521163F8D5 on the 6BE6D8 but no way , i done wrong ?
    Reality of life :
    3: everyone lies
  16. #14
    ASCM's Avatar
    Oct 2018
    Try to make diagnostic with xentry
    I you have internal fault maybe the das data corrupted write a good dump in
    Das after that relearn key
  17. #15
    dariobmw's Avatar
    May 2010
    near THE NORTH FACE
    Thanks for hint , but if i replace the eep content with a good one i lost the motor / das alignement ?
    and if yes how to realign ?
    Reality of life :
    3: everyone lies
