Results 1 to 5 of 5
    Sep 2014
    Somewhere
    Default Dacia logan 1,5 DPF off check needed
    Hi to all!
    Can somebody check if I made good DPF off on a Dacia Logan 1.5 Diesel year 2015? ECU Bosch 0281030439.
    Both files attached.
    Thanks!
    pike's Avatar
    Sep 2013
    will not work with disconnect sensors.
    WinOLS5, custom files for diesel ECU
  3. The Following User Says Thank You to pike For This Useful Post:
    Jashmine1983 (30th May, 2020)
    Sep 2014
    Somewhere
    Quote Originally Posted by pike View Post
    Soo..is good DPF off file...but with all sensors on.
    pike's Avatar
    Sep 2013
    you can try and tell everyone later
  6. #5
    Sep 2014
    Somewhere
    I've tested It and works good.
