I don't think that is possible to retrieve the info for EZS from the key
How do you read 0D69J?
Hi m8īs
I have a problem with an EZS of a W208. Part number is 2085450108, it has 2 motorola 0D69J with mask ZC410699cfu (outside) and ZC410710cfu (inside). Both of them are erased (all FF) I donīt know why, the owner of car bring me the EZS and key because he canīt turn key.
The key is one with motorola 0F82B (567.880.021) and I have the key dump readed with xprog.
Could be possible make the files for EZS using the key data?
If itīs possible, could someone help me with that?
Thank in advance
If my post was helpful press Thanks button!!
I read them with VVDI prog and never had a problem
Anyone can confirm me if itīs possible to make a Micro files for EZS using the key data? With the data of an EZS with same part number could be possible to modify this data with original key data?
No, depending on the tools you have it may be cheaper to order blue key than to waste time with cloned tools......
Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
