Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    Mar 2020
    Default PSA EDC16C3 1.4 HDi in limp, eco mode, inject. ECU fault, uneven flow correction
    The car has had immo off with your help (read here).
    I shout a massive big THANK YOU to all who helped bringing my car back from the dead!!! Recycling cars like that is better for the environment than buying new electric cars
    It's not 100% healthy yet. After you nicely did immo off for me, the car started! But is very underpowered, easily stalls on load, is running rough (engine is shaking, twitchy; it used to run smooth in the past: read what happened to this car before immo-off here).
    I cannot rev past ~1500rpm. MFD still says "Eco mode" even after driving around.
    Dashboard always has "battery not charging" lit up (though alternator works), and sometimes handbrake light (even when handbrake is off), speedo, tacho and oil temp needles do not work at all. Fuel and water temp gauges work fine. Wipers do not work, indicators work.
    After immo off, I could finally clear ECU faults, and now I have two only faults (1 new):
    Permanent fault. Injection ECU ECU internal fault (must be the main problem?)
    P0382    Preheating relay circuit fault. Plugs permanently supplied
    ^ I measured continuity around disconnected glowplugs, they seem shorted out -- probably once overheated and welded with the block, so I disconnected the relay altogether.
    And now I am able to rev up to 2800rpm (but still in limp), car has a bit more power, but still running rough. Live data:
    measured injected flow:                 9.02 mg/impulse
    cylinder injector 1 flow correction:    2.34 mg/impulse
    cylinder injector 2 flow correction:   -1.48 mg/impulse
    cylinder injector 3 flow correction:   -1.15 mg/impulse
    cylinder injector 4 flow correction:    0.36 mg/impulse
    injector 1 and 4 control error status:  no fault
    injector 2 and 3 control error status:  no fault
    ECU control unit condition: ECU is not locked (before immo-off it said locked)
    status of the coded engine immobiliser programming: after-sales status
    problems detected when transmitting the unlock code: No problem detected (before it said awaiting response from BSI)
    BSI fault still remains:
    Permanent fault. Absence of communication with the engine management ECU.
    BSI settings -> immobiliser status:
    ECM locked: Yes
    transponder marker recognized: Yes
    transponder key number learned: 1 (beep test works)
    number of high frequency remote control commands learned: 1
    BSI Matched: yes
    BSI in Anti-Scanning mode: No
    blank BSI: No
    high frequency remote control battery: good
    I hope you can help me cure it further Thanks!!
    Gammoudi's Avatar
    Dec 2017
    ECUS
    THIS IS SOFT PROBLEME POST CALCULATEUR NUMBER AND I WILL SEND YOU DUMP IMMO OFF
  3. The Following User Says Thank You to Gammoudi For This Useful Post:
    nblee (1st June, 2020)
    Mar 2020
    Quote Originally Posted by Gammoudi View Post
    Thanks, but it's already immo off: https://www.digital-kaos.co.uk/forum...mmo-off-please
    Gammoudi's Avatar
    Dec 2017
    ECUS
    THE PROBLEME IS NOT IN EPROM ITS IN FLASH
  6. The Following 2 Users Say Thank You to Gammoudi For This Useful Post:
    2angel (30th January, 2025), nblee (1st June, 2020)
  7. #5
    Mar 2020
    OK here you are my friend! Internal and external flash mems of the ECU
    Internal flash:
    MPC500 Family    Version: 0x00020020
    MPC555/6    Part Number: 0x30320800
    EPEE Status: 1
    Flash Identified: Am29BL802C
    Family Identified: EDC16 PSA
    Info ECU
    SW: 1037363558
    Reading Internal Flash ...
    Reading Block at: 0x00000000
    Reading Block at: 0x00068000
    Reading Configuration Block
    Chk8:2884  Chk16:135A  Chk32:DF01045B
    Saving: C:\Documents and Settings\nblee\Desktop\BDM 100\bdm100\DimSport\E2P\mpc5xx-internal-flash.mpc
    External flash
    Reading Am29BL802C...
    Reading Block at: 0x00800000
    Reading Block at: 0x008C0000
    Chk8:53AC  Chk16:7F4A  Chk32:86816829
    Saving: C:\Documents and Settings\nblee\Desktop\BDM 100\bdm100\DimSport\E2P\Am29BL802C-external-flash.bin
  8. #6
    Gammoudi's Avatar
    Dec 2017
    ECUS
    HERE REPORT AFTER TEST
  9. The Following User Says Thank You to Gammoudi For This Useful Post:
    nblee (2nd June, 2020)
  10. #7
    Mar 2020
    Thanks, but my ECU has different part numbers written on its sticker as opposed to those inside your archive:
    BOSCH
    0 281 010 707
    020603 (this timestamp matches with 0x0007-0x000C offset bytes in my eeprom dump, your one says 011030)
    1039S00146
    1855 0525
    28603
    9647158380
    EDC16C3  82
    96 477 857 80
    More info from MPPS:
    More info:
    ECU Hawdware type: 1037363558:C18252B :00
    Peugeot Hawdware Number : 9647158380
    Peugeot Software Number : 9647785780
    Bosch Software Number : BOSCH EDC1
  11. #8
    Gammoudi's Avatar
    Dec 2017
    ECUS
    it is not a probleme just test its work ok with your car
  12. The Following User Says Thank You to Gammoudi For This Useful Post:
  13. #9
    Mar 2020
    Ok thank you, should I also write your EEPROM with immo off so it matches the rest? Also both internal and external flash memory should be written?
  14. #10
    Gammoudi's Avatar
    Dec 2017
    ECUS
    YES PROGRAM ALL
  15. The Following User Says Thank You to Gammoudi For This Useful Post:
  16. #11
    Mar 2020
    Flashed everything you gave me...
    LIMP MODE IS GONE! I can rev to 4800 RPM now THANK YOU!!! (your eeprom immo off two parts did not match inside .e2p, I fixed it and attached here)
    Also Peugeot Planet 2000 now correctly accepts 8HX Euro3 ECU selection.
    I also had to plug back glowplug relay to completely get out of limp mode.
    Remaining problems:
    No wipers, no low/high beam headlights; on dashboard speedo gauge, RPM gauge, oil temperature gauge -- these are still not working..
    MFD goes black after saying ECO-MOD, even after driving the car around.
    When engine is running, eventually dashboard goes completely dark (except battery light): fuel gauge stops working etc.
    ECU permanent faults (never seen before):
    Coded anti-start Code ADC2 reading or writing error
    CAN communication Absence of communication with the BSI ECU
    CAN communication  Engine ECU dead
    We are close to get the car 100% back on the road
  17. #12
    Gammoudi's Avatar
    Dec 2017
    ECUS
    YOU ADD THE REST OF YOUR EPROM ADD THE REST OF MINE IF DID NOT WORK TRY THIS ONE
  18. The Following User Says Thank You to Gammoudi For This Useful Post:
    nblee (3rd June, 2020)
  19. #13
    Jul 2013
    yorkshire
    Check all fuses [carfully] around battery inc wires behind battery.
  20. The Following User Says Thank You to autoden For This Useful Post:
  21. #14
    Mar 2020
    Thanks Gammoudi and autoden, I shall do as you instructed when I get back to garage.
    Just to re-iterate: this car had an out-of-family ECU fitted (EDC16C34), but BSI kept original. morgano said that BSI and ECU from different cars start real nightmares (how do they "poison" each other during comms?) even after putting original ECU back in..
    If your suggestions don't work out, will flashing BSI be an option?
    My car comes without ABS unit from factory by the way. And it's 2002, so without DPF/FAP (which was introduced not long after).
    As you can see in my first post, BSI still thinks that ECU is locked (even after ECU immo off).
  22. #15
    Gammoudi's Avatar
    Dec 2017
    ECUS
    because there is no communication between bsi and ecu
  23. The Following 2 Users Say Thank You to Gammoudi For This Useful Post:
    2angel (30th January, 2025), nblee (3rd June, 2020)
