Results 1 to 3 of 3
Thread: 95256 Cat file
    Jan 2017
    Default 95256 Cat file
    Testing a cat ecu. This dump is from a 95256. Does anyone see the hours in this file(should be 7051). Reason asking I was unable to see it and when placed back in machine to run up 1hour. Got nothing reread chip with upa got all 00's and could not edit it. Hoping this file wasn't corrupted before what I believe to be chip failure or my ignorance. Thanks all
    gogalv's Avatar
    Aug 2010
    You'll need pictures from all sides mate .... ? PremierD
  3. The Following 2 Users Say Thank You to gogalv For This Useful Post:
    Jd40 (31st May, 2020), jomberykaso (31st May, 2020)
    Jan 2017
    Thanks! Relief it was not corrupt. As I dont have a good dump to replace with. It is out of cat 279d ecu. First believed it to be located in the dash. But on these they are located in ecu under the cab. Would you be able to help edit this to 1987?
