Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Apr 2020
    Default RenOLink 1.87 se143-b china cable ( DDT2000 Base 12.2019)
    Product Description
    • Renolink OBD2 for Renault ECU Programmer
    • Latest Version V1.87
    • Software Language: French + English
    • virginiser of steering assitst for Renault Megane 4, Renault Scenic 4, Renault Kadjar and Renault Talisman.
    • Codding will do automatically at the first ignition.
    • Also database from december 2019 was added.
    Renolink OBD2 Renault ECU Programmer ( ECU-Airbag- Key )
    Reno'link has many features like UCH matching,airbag programming,engine ECU programming,key coding, key deletion, dashboard coding, eeprom and flash reading and writing in Renault and Dacia vehicles.
    You can connect Reno'link programmer device to vehicles via OBD socket, and you can make programming easily and delete memory and introduce units without disassembling ECU, EPROM and flash drives.
    Thanks to the Reno'link, you can easily virginize and re-program the parts like UCH, motor bracket, indicator, airbag module, fuse table, which are installed new or used ones on the Renault and Dacia vehicles.
    Renolink OBD2 Functions List:
    -Eprom read / write
    -ECU Resetting
    -Clear Crash Airbag
    -Airbag reset
    -Airbag Virginize
    -KEY Programming
    -TDB (cluster)
    -Indicator Programming
    -ECM Programming
    -UCH Programming
    -EPS Virginizer
    -EPS Resetting
    New version of Renolink 1.87
    In this version was implemented:
    - reading of PIN code for HFM Renault Clio 4 and Renault Captur 2016+, a valid Card is required to teach HFM, because the procedure virginses it.
    Also a new database from december 2019 was added.
    - this version we added cards programming for Clio4 (2012-2015),also a new database from July 2019
    Was added:
    - learn ecu from DACIA Logan 2 / DACIA Sandero / DACIA Lodgy / DACIA Docker / DACIA Duster ph2
    This update is for well known problem with ECM V42 )
    - Read/write eeprom and read/write flash for dashboard Dacia Logan2 / Dacia Sandero2 / Dacia Lodgy / Dacia Docker / Dacia Duster ph2 from years 2013-2014 and 2014-2017
    -Read/write flash, eeprom and km were added for dashboard (VDO) Mégane 3 and Fluence 2015+
    - Was added into program - read and write flash, eeprom and km for the Laguna 3 dashboard.
    - Read/write km,- read/write eeprom, - read/write flash for dasboard Renault Fluence.
    - Also was added key programming UCH BMT Sagem for Dacia Solenza, Dacia Supernova, Renault Twingo, Renault Kangoo, Renault Master (years 1998-2003)
    - Read/write km for dashboard Renault Modus
    - Read/write km, read/write eeprom for dashboard Koleos
    KEY PROG
    key programming for Dacia Logan 2
    key programming for Dacia Sandero 2
    key programming for Dacia Duster ph 2
    key programming for Dacia Lodgy
    key programming for Dacia Dokker
    key programming for Renault Clio Symbol 3
  2. The Following 63 Users Say Thank You to liilmrll For This Useful Post:
    Adamdad (20th February, 2022), adiltarjeta (22nd October, 2023), amd57 (4th January, 2022), antonypaul (19th July, 2023), autocargo (25th December, 2020), benjarray (4th July, 2023), blackpearlpilot (21st August, 2020), bmotor60 (5th November, 2020), boab281 (11th April, 2023), casper2 (26th October, 2022), chispazo (16th August, 2023), Col19 (13th December, 2020), corfumadness (5th June, 2020), Deivid Roza (27th April, 2022), electronicdeivi (7th December, 2022), estwood68 (17th June, 2021), fboudoukha (19th November, 2021), Felorgas (29th April, 2023), Florin (8th August, 2020), Gery (29th November, 2021), ggaltstart (1st August, 2020), gost (30th October, 2022), hassanbeach (12th September, 2021), hbalazs (26th October, 2020), hfcm (25th April, 2022), hocine6325 (8th November, 2020), inisight (25th February, 2024), joejam (12th December, 2021), Kfouka (6th August, 2021), kiwi (14th February, 2021), Kurtkoeln (4th August, 2023), Louislesinge (31st May, 2020), mardude (9th June, 2020), marsete (12th February, 2021), mastercracker (9th December, 2020), mehdi24 (7th February, 2023), Michael28 (4th February, 2021), Mohamed4200 (23rd October, 2022), mylus (4th November, 2020), Oto kilitsan (15th February, 2021), pikaone (8th March, 2021), ptitjo44 (2nd May, 2022), pzidecode (17th August, 2022), raimongil (25th January, 2023), RedNix (24th November, 2020), rikrdo (22nd May, 2022), sapopt (28th August, 2020), shtyrya2 (9th November, 2020), sntfrancisco (29th September, 2023), Stahab (19th November, 2020), stefan11 (16th July, 2021), tazz75 (8th June, 2020), TecnologiaSelec (30th April, 2022), TiagoF (20th October, 2020), TuAz (21st July, 2023), undo2 (30th August, 2023), vdiag (3rd September, 2021), whoopty (14th February, 2021), wloosik (15th September, 2023), Y0SHI (3rd June, 2020), zizitro (10th February, 2024)
  3. #2
    Dec 2009
    wich interface working with this version ?
    the blue one or the red ?
    I helped you press thanks
  4. The Following 5 Users Say Thank You to babouches For This Useful Post:
    benjarray (4th July, 2023), hassanbeach (12th September, 2021), olinad62 (6th November, 2021), roman10 (13th May, 2022)
  5. #3
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by babouches View Post
    non... you need to have the interface that go's with this china soft...
  6. The Following User Says Thank You to ricked For This Useful Post:
  7. #4
    Apr 2020
    Good Luck for All
  8. The Following User Says Thank You to liilmrll For This Useful Post:
  9. #5
    Dec 2009
    Have you got link for good selller ? And price ?
    thanks !
    I've got the bleu one device, and not working with the software
  10. The Following 4 Users Say Thank You to babouches For This Useful Post:
    hassanbeach (12th September, 2021), Kfouka (6th August, 2021), wloosik (15th September, 2023)
  11. #6
    drupal's Avatar
    Jun 2020
    hi, i have question Can RenoLink Damage the Ecu or BSI of client ?
  12. The Following 2 Users Say Thank You to drupal For This Useful Post:
  13. #7
    Dec 2018
    Quote Originally Posted by drupal View Post
    everything can only be paired with the user's hands
  14. The Following User Says Thank You to Catalizator For This Useful Post:
  15. #8
    yahia1908's Avatar
    Dec 2009
    Hello everyone, often the concern for Renolink to be active comes from the mismatch between the license and the interface.
    Clone interface = same number
    Obdlink SX Ori interface: different number
    To ensure the ID; maker; equipment; firmware. See link below (News).
    This utility can help explore dependencies (line # 2 in the same file)
    FT_PROG is a free EEPROM programming utility for use with FTDI devices. It is used to modify EEPROM content that store FTDI device descriptors to customize designs. FT_PROG also includes the ability to program Vinculum firmware. NOTE - Use of some of these utilities by an end user may result in a device being rendered useless.
    ps IN NO EVENT CAN I BE HELD RESPONSIBLE FOR ANY DAMAGES (INCLUDING, THOSE CAUSED BY LOST PROFITS, LOST DATA OR WORK INTERRUPTIONS) DUE TO USE.
  16. The Following 6 Users Say Thank You to yahia1908 For This Useful Post:
    Col19 (8th December, 2020), galiza (7th December, 2020), hassanbeach (12th September, 2021), shtyrya2 (9th November, 2020), Stahab (19th November, 2020), tavi1969 (10th July, 2021)
  17. #9
    galiza's Avatar
    Jun 2011
    Do you are talking about this?
    I wonder if it possible change the interface ID to be use with DDT2000
    Somebody knows something?
    It is better to arrive 10 minutes early, than to be bored all the way.
  18. The Following 13 Users Say Thank You to galiza For This Useful Post:
    azedine1 (30th June, 2021), barmaleytm (1st March, 2022), Col19 (8th December, 2020), elektret (16th November, 2021), estwood68 (22nd June, 2021), hassanbeach (12th September, 2021), Hayssam1 (3rd December, 2021), kivlov001 (27th August, 2021), mardude (12th December, 2020), Nols Theron (21st May, 2022), polymeca (22nd May, 2023), sntfrancisco (17th September, 2023)
  19. #10
    Nov 2021
    Hi guys, enable me to write renolink, thank you very much
  20. #11
    Nov 2021
    Ragazzi come posso accedere a renolink 1.87.txt ?
  21. #12
    Apr 2022
    Hi there
    link to eeprom obdlink sx.rar dead or I can not download it?
  22. #13
    May 2010
    Quote Originally Posted by galiza View Post
    HI. This eeprom from original obdlink sx or from china cable?
  23. #14
    Dec 2009
    Argentina
    thanks............................................ ...............................
  24. #15
    Jan 2023
    Default I can't activate the interface
    Quote Originally Posted by liilmrll View Post
    Product Description
    -Eprom read / write
    -ECU Resetting
    -Clear Crash Airbag
    -Airbag reset
    -Airbag Virginize
    -KEY Programming
    -TDB (cluster)
    -ECM Programming
    -UCH Programming
    -EPS Virginizer
    -EPS Resetting
    Was added:
    KEY PROG
