No OBD solution. Need to read Bcm on bench, then you can add via OBD
Sent from my DUB-LX1 using Tapatalk
VVDI2 Add Porsche Cayenne smart key do I need to remove BCM to read data eeprom on table or is there a way all OBD?
Hayssam1 (7th January, 2023), immoneard (22nd August, 2020), Manta1600 (31st May, 2020), RG550 (31st May, 2020), super jumbe (31st May, 2020)
Also you must have second pair of balls to take this job
ghostrider72 (31st May, 2020), qwojtus (31st May, 2020), super jumbe (31st May, 2020), Wilber Pardo (15th June, 2020)
Any one got idea which chip to read on BCM?
1L15Y or 1N35H or 2M25J or 5M48H (there are 4 kinds of Freescale).
Be careful.
immoneard (2nd June, 2020), super jumbe (31st May, 2020), Wilber Pardo (15th June, 2020)
Faraday (29th December, 2021), immoneard (2nd June, 2020), jodge (10th May, 2021), super jumbe (1st June, 2020)
This is 1N35H and you ask Microtronic directly what is the success rate.
Second hand BCM wont help you at all, and vvdi prog not unlocking them very well.
My advise before you do the job. Make sure car stays on neutral, steering straight up, windows fully close.
Manta1600 (1st June, 2020), super jumbe (1st June, 2020), Weasel3 (1st June, 2020)
p1et (30th April, 2022), super jumbe (1st June, 2020), Wilber Pardo (15th June, 2020)
if we change mcu
With new one does new one mcu need unlocking or just need to write the backup
From ori mcu ? (Does anyone tried to read and write with oem xprog)
Sent from my SM-J415F using Tapatalk
I have checked most videos the reading module just easy look at the video, I have ordered used module from ebay for practice before going for the job.
https://www.youtube.com/watch?v=5D9tH10YtgQ
