It's been a long time since iv'e used this sort of keygen, the last time was on my pda & it was a tomtom 6 keygen,
If I remember, I made a directory on the "C" drive called "map" & put the (keygen + map file only in there) to make it easy,
@ stage 4 you will have to type "tt8_keygen2.exe (map file name (including the .ext)) (the unit device id number)
i.e: "tt8_keygen2.exe western europe map.aeu 123456" enter, it should then give you the map unlock code to type in your unit.
the only thing I cannot remember is if the map file has got spaces in the name, you might have to put "_" in its place, i.e: "tt8_keygen2.exe western_europe_map.aeu 123456" enter
but make sure there is a space between the keygen.exe & map filename + space between the map file name & the device id number.
The dos command @ step 4 has to be one long command, hence the reason of having a small directory name & in the root "C" with just the 2 files in there, to save typing the long directory names.
What is the full map name that you are using including the .extension?
--- Ian ---
m8 try different way, same tings but, bit easy
download this then extract in some location,
run (right click, open as administrator)
first window if u need crack new map click tt_keygen8.exe
then ID ur device
then browse location meta file
then browse loction map
and then below click run DCT or something like that.
that keygen was ace m8 thanx ,, one more thing have u the latest speed cameras and where to l put them ,cheers
here we go
Australia, Austria, Belgium, Czech Republic, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, South Africa, Spain, Sweden, UK, USA and Canada.
and meta file for these spedcams
put all files in ''radars'' folder into map folder, then file ''meta'' put in root tomtom device or SD, then u need crack maps and radars using any map activator, do this same way as u cracked maps. :-)
top man worked a treat didnt think l needed to use the keygen again .,. great
Hi guys. I am after a greece map for tomtom 7 windows mobile. anyone i would appreciate it. thanks
Try news groups, mostly found in alt.binaries.warez.pocketpc.gps.
Thanks for this post.
