Because you need to clear ecu faults even if there are no faults , make a dtc erase in the engine ecu and the car will start
Guys I cleared airbag ecu, engine is tur ING but not starting.
Car is a kangoo 2009 with 1.5 diesel engine.
What tool can remove this non starting problem from Ecu?
I have Renault tool from immo-tool is this ok or do I need can clip or Reno link.
No dtc active Btw en airbag light is off.
Wbr Adam.
rafal (2nd June, 2020)
No can clip, I can buy it but it takes a while .
Can't the Renault tool from immo tools help me?
It can clear impact from edc16 but I cant find option for this Ecu.
Wbr
read ecm with any diagnostic tool. is there any connection with him?
Yes I can connect but no dtc
Does your scan tool have an ecm computer unlock feature?
I have no idea how to do this without canclip
need help
now my goal is to buy xp-005
who will help?
Hi! I have a megane 3 2012, and after crash doesnt start. I think is a fuel injection cut. because crash info is in the airbag module and engine ecu.
renolink have function to clear crash from airbag module, but i don`t know how to clear ecm.
after crash,the airbag unit send the fuel cut comand trough CAN network, the engine does not start anymore.
make a diagnostic to engine management system and make a clear memory fault,even if there is no fault stored..doing this the engine will start,if no any other problem..make a diagnostic on entire car modules
