I dont know why you dont search forum befoure posting... You need read D flash, not P flash....
Read P flash and post here.
With Bdm conections:
BKGD
RESET
VDDR (5v)
VSS
As the partner tomic19 says, you need to read the D_FLASH and with that reading you can make a new EPP and then it will work without problems.
ĦĦĦĦĦĦIf my information served to help you, please click on THANKS + REPUTATION!!!!!
If you dont have the dflash you can use this file, but you have to code the module after installation...
Ok thx, i try!
Hi all any help appreciated. this is my dflash read with genuine upa-usb it appears to be corrupt.
anyone able to repair, i see dlashtoeee software appears to do it or will i need to use a virgin file?
Try read again... Corupt dump to me....
Yes I tried it at FRM3 D-Flash to EEPROM converterhttp://tlvps.tomvanleeuwen.nl/frm/convert.php
The vin no. is correct I was hoping there is someone who can run it through dlashtoeee software for a small fee.
Otherwise I need to write from a virgin file & code it.
I noticed that my UPA may not have the latest script for this processor.
I have searched around but can't find it. My original script does not have options for p/d flash.
it would be nice to have the latest script if anyone has it
Please see pics for difference
Hello, i'm new here and i have similar problem where my dflash was 0 and the eeprom was also 0 olny the p-flash was i able to back up
