Results 1 to 6 of 6
    Mar 2019
    Earth
    Default mercedes vito start error HC08 0J66D 24C04
    Hi guys,i m having a mercedes vito with start error,i ve read the immobox and ecu ,and used that program called Mercedes Start Error Fix v1.3 wich generated succesfully new dumps for immobox and ecu.Now the car is pretty far away and i wanna make sure the solution is wright.Here you have both original files and mod .Thanks
    ps ,i don t need files modified with program i need you guys to tell me is the solution is right.
    Mar 2019
    Earth
    Ok quick update ,with solution that i posted the car does the same (start error) .
    Can someone help me with a working solution ?
    tazz75's Avatar
    Nov 2018
    Where is HC08 content ?
    tazz75's Avatar
    Nov 2018
    Hy..try my files and report back..
    Mar 2019
    Earth
    Looks like your solutin is the same dump on HC08 with what i writed in immobox.The only diference in ECU E2P VIN NR removed.
    I will test and report,maybe ll work .
    Thank Taz
    Mar 2019
    Earth
    Do i need to make a new transponder?
