Results 1 to 3 of 3
    Apr 2016
    Europa
    Default Peugeot 307 Sagem S2000-28 eeprom virgin
    Hello
    need virgin eeprom for 95080
    thank
    Oktawian's Avatar
    Sep 2016
    Pin E8AP or APE8
    Try this file and report back. If it will not works, put all FF to the dump and write it back.
    Apr 2016
    Europa
    good evening
    BSI tied 1 key with pin E8AP. I tried to register a new key again. I registered successfully, and in the parameters ECU writes - the block is locked.
    with immo off from s2000-3.. the engine starts but does not work correctly. I would like to do it normally. How to remove the block is blocked?
