Hi to all!
Please help with good DPF OFF file on Touran 2.0 (engine CFH, 103 KW) EDC17C46, 03L 907 309 R, 0281016674.
Ecu is read with K-tag as P199.
Thanks!
PS: I've tested with DPF Remover 2017.05 and gives U0302 DTC.
Hi to all!
Thanks!
tri this if it work
Jashmine1983 (3rd June, 2020)
Thanks! But I have same U0302 DTC and evac presure sensor DTC.
I must disconect sensors...or let them connected? Are the sensors DTC's deleted?
Try to disconnect and see if is solve the problem
Guessing I was testing the files.......
Please someone provide a good solution for this ECU.
Thanks!
working dpf off
pass = tnx+rep
[QUOTE=F4STuning;3886309]If want good solution i suggest to go in your local tuner. Criticizing who does your job for free is the height[/QUOTE
I'm not criticizing someone? It does not seems right to learn on others car. Just do not answer to thread...is just simple.
this solution should work
Jashmine1983 (7th June, 2020)
just did yesterday same ecu, adblu off only tested!
