Results 1 to 10 of 10
    Nov 2018
    Default Edc17c74 problem read
    Hi. I need read EDC17c74 my ktag red clone and i have problem. I use gpt cable, i use SW 2.23 and 2.25 and not succes. sad Car is Skoda Octavia 2018 year 2.0tdi 150hp. All ecu so far I read no problem. (sid 803, edc17c46, and many other). Someone help? Regards
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    pcm flash module for vag ,very cheap ,good and genuine tool
    virtual read and write with checksum all you have
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  3. The Following User Says Thank You to AVDigitale For This Useful Post:
    drewdom (3rd June, 2020)
    buy ktag original and read
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
    Nov 2018
    Is that all you have to say? ���� Very Thanks
    Sep 2010
    Maybe you have unrealistic expectations as clone ktag user ?
    May 2017
    KTag works fine with , also AT Bench Mode...
    Cheapest option PCM flash
    Newmotors's Avatar
    May 2019
    brazil
    hello friend i had the same problem when reading this ecu, try to use protocols with gpt i was read this ecu with protocol 675
    Newmotors's Avatar
    May 2019
    brazil
    some people on this forum are ignorant , many have started now and are not in a position to acquire genuine flashers, they forgot that one day they were newbies and already did a lot of shits in the beginning , the reason for this forum is to help each oter, we all know that genuine programmers are and writes very well , but as i said, everyone who starts from the bottom doesn't have the money to buy genuine ones if it won't help be quiet
  10. #9
    Nov 2018
    Thank you. Unfortunately, no protocol works with my ecu :/
  11. #10
    Jun 2013
    EU
    Quote Originally Posted by stixo View Post
    where you based?
