Results 1 to 9 of 9
    Sep 2016
    Default Hyundai SANTA FE SIMK43 IMMO OFF
    Всем привет! помогите мне сделать иммо прочь!
    Всем привет! помогите сделать immo off
    speedy100's Avatar
    Athens
    Immo Off not possible to this ECU-Immo system.
    It is using Rolling Codes...
    Your file is RESET. You can try to program the ECU and put it on car. Turn ignition on and wait 30 seconds. Turn ignition off and wait 30 seconds.
    Turn ignition on and start the car.
    If it does not start You need to program the RESET file again to the ECU and this time You need to use Good diagnostics to code it back to the car.
    Try and report back please.
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  3. The Following 2 Users Say Thank You to speedy100 For This Useful Post:
    arthueascii (8th June, 2020), Kent00 (6th June, 2020)
    Sep 2016
    Friend! these cars have immo off!
    Try one of these and let know.
    WBR, Marek
    Please do not spam my PM asking for help.
    Use forum, that is why we are here.
  6. The Following 2 Users Say Thank You to tech_cz For This Useful Post:
    Kent00 (5th June, 2020), volodin69 (5th January, 2021)
    Sep 2016
    Quote Originally Posted by tech_cz View Post
    попробуйте один из них и дайте знать.
    WBR, Marek
    Большое спасибо! Вариант 2 работает !!!
  8. #6
    So why you did not press the THANKS button?
  9. #7
    speedy100's Avatar
    Athens
    Quote Originally Posted by Kent00 View Post
    It would be very easy for me to tell you so. You would not know if it worked OK
  10. #8
    Hello mr tech_cz can you share the pass for your archive, thanks
    Somesoul
  11. #9
    Sep 2013
    WBR, Marek
    Pass please
    Thank you so very much
    تم الإرسال من Redmi Note 6 Pro باستخدام Tapatalk
