Results 1 to 6 of 6
    Dec 2019
    Default TOYOTA YARIS 89170-0D040 NEED original DUMP
    Hello i have this dump with B1100 AND B 0133 errors
    can some one repair this dump or some one has un original one ?
    Thank you for your help
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by Nicolas13007 View Post
    it is have crash or no?test and report.
  3. The Following User Says Thank You to superjet For This Useful Post:
    Nicolas13007 (5th June, 2020)
    Dec 2019
    No crash reported i will try this this afternoon and report back
    Dec 2019
    I tried the dump is the same problem B 1100 Airbag sensor current and B 0133 Passenger pretensioner squib, short circuit to+ battery , current
    when i disconnect the pretensioner tha gives me open circuit and when i put a resistance 2.2 ohms in the connector of the pretensioner short circuit to + ,, if i put the resistance to the aibag line directly to airbag ecu that gives me also short circuit to +
  6. #5
    Dec 2019
    What do you think ? The owner told me that he had a back push by a allroad vehicule , can that be the cause ? Can u make me a crash clear ?
  7. #6
    Dec 2019
    Problem solved i changed the ecu
