Any PIN with a new key.
I have a problem with this car, someone tried to fix it but without success. The problem is that the BSI HC912 file is corrupted, VIN number pppppppppp. I made a virgin BSI and set up PP2000. Now I have a problem with IAW 4MP2.01, the previous master has already done something with AM29F200BB, the read file does not contain a PIN number and the file is damaged. I found another matching file made it to be Virgin, but I can't pair it with BSI to PP2000 because I don't have a PIN code on BSI because it's Virgin, and IAW 4MP2.01 is Virgin so it doesn't contain a PIN code. How do I pair them?
StojkePN (5th June, 2020)
Thanks I will try with the new transponder and coding over PP2000
I couldn't match it. Bsi Virgine, Motor ECU Virgine, New transponder. Through the PP2000 program I went to the BSI Replaced option, I entered the VIN number, and the settings that were offered. When entering the PIN code, it displays that the PIN code is incorrect.
What's the problem?
I’ve worked Virgin a lot of times on this BSI with the HC912 and I’ve never had a problem, but the motor ECU has always been unopened, now someone before me has been working and touching the 29F200 and I don’t know what he did.
Edit: Does anyone have a valid Virgin dump for Motor ECU IAW 4MP2.01 AM29F200BB?
Attached is the dump I read from the Motor ECU.
Magneti marelli
IAW 4MP2.01
27K9LK172
HW 16.530.014
HW 9642427080
SW 16.581.024
SW9646345080
Can any of this file make virgin or immo off. I tried with the programs Universal immo decoder 3.2, AEtool, Immo service tool 1.2 but they don't do the virgin properly.
enjoy......................
pass=buttons
need help
now my goal is to buy xp-005
who will help?
achinoto (15th October, 2020), Ecumotor (12th December, 2020), IPrometheus (11th November, 2020), skens (3rd June, 2023), StojkePN (13th June, 2020)
Pass,please.Thank you in advance.
plase pass thanks
Please Pass thanks.
