Results 1 to 8 of 8
    Jan 2019
    chile
    Default FRM3R E70 AHL HELP
    Hello mates... i have a frm3r e70 ahl from a bmw x6 e71 and i have no comunication with frm module via obd... can somebody help me a little..
    so hooked up my original upa programer... read d-flash and p-flash.... when i try to convert d-flash to eee... it says its corrupted...
    anybody please help me...
    FRM3R E70 AHL
    9230433-01
    HW:06 SW: 12.20.00
    S:6135
    30-08-10
    535053MF400
    If I was helpful DONT forget the THANKS and REPbutton
    Jul 2015
    Quote Originally Posted by chriaran View Post
    FRM3R E70 AHL
    9230433-01
    HW:06 SW: 12.20.00
    S:6135
    30-08-10
    535053MF400
    Here we go....Just flash the EEE and your pflash. No coding required....
  3. The Following User Says Thank You to syncroflash For This Useful Post:
    asto (19th May, 2022)
    Jan 2019
    chile
    Quote Originally Posted by syncroflash View Post
    is it necesarry to reflash pflash.... do we partition dflash to flash pflash and eee?? thanks for all the help
    i flashed everything... and extracted dflash again and went to convert to eee and i got this error
    Jul 2015
    Why are you trying to generate the EEE again. You got it already. Just flash the EEE (you have to change the filesize in the flashtool to 4096 - it should automaticly ask for it= and after that you write the pflash. Thats it - nothing more to do.
    You dont have to flash a dflash, just EEE and Pflash. Which tool do you use to flash?
    Jan 2019
    chile
    im using upa programer original..... how do i change the filesize on the eee???
    ricked's Avatar
    Apr 2016
    Europe
    there is "noting" to change on the file size of eee, you doing something wrong...
    Jul 2015
    Normally the programming software like xprog or vvdiprog asks for the partitionsize. Here you have to set to 4096 for EEE. After you flashed this partition you flash the Pflash. Then its done.
    Nothing more to do.
    Jul 2015
    Here is the setting for UPA
