Hello mates... i have a frm3r e70 ahl from a bmw x6 e71 and i have no comunication with frm module via obd... can somebody help me a little..
so hooked up my original upa programer... read d-flash and p-flash.... when i try to convert d-flash to eee... it says its corrupted...
anybody please help me...
FRM3R E70 AHL
9230433-01
HW:06 SW: 12.20.00
S:6135
30-08-10
535053MF400
If I was helpful DONT forget the THANKS and REPbutton
asto (19th May, 2022)
Why are you trying to generate the EEE again. You got it already. Just flash the EEE (you have to change the filesize in the flashtool to 4096 - it should automaticly ask for it= and after that you write the pflash. Thats it - nothing more to do.
You dont have to flash a dflash, just EEE and Pflash. Which tool do you use to flash?
im using upa programer original..... how do i change the filesize on the eee???
Normally the programming software like xprog or vvdiprog asks for the partitionsize. Here you have to set to 4096 for EEE. After you flashed this partition you flash the Pflash. Then its done.
Nothing more to do.
Here is the setting for UPA
