Results 1 to 8 of 8
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    Default Mercedes Sprinter W906 CDI EDC16CP31
    I have Mercedes Sprinter W906 CDI EDC16CP31 someone tried to Remove DPF in wrong way, now the file has wrong checksum and many DTC,
    please I need DPF OFF, correct checksum and remove all DTC.
    Many thanks in advance.
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
    stanislav georgiev's Avatar
    Oct 2014
    България
    Write this file, everything should be fine.
  3. The Following 3 Users Say Thank You to stanislav georgiev For This Useful Post:
    3inferno3 (7th June, 2020), konq100 (8th June, 2020), pinkfloyd5eg (6th June, 2020)
    Thank you so much, I will try and report....
  5. The Following User Says Thank You to pinkfloyd5eg For This Useful Post:
    stanislav georgiev (6th June, 2020)
  6. #4
    Thanks for your great work, the file worked like a charm, only the mechanic took it on a test drive and I am sure it will be fine.
    I am sorry to bother again, but after the test drive the car shows this DTC code is 2671-002 monitoring function quantity injected, is it because of something in the ECU file or do you think this has nothing to do with the file and it is a mechanical problem !!
  8. #6
    Oct 2014
    България
    The file is fine, I've done a lot of sprinters, I'll check the error code on Monday.
  9. The Following User Says Thank You to stanislav georgiev For This Useful Post:
  10. #7
    Mar 2020
    Adjust injector zero quality with diagnostic tool and will be fine.
    Wysłane z mojego SM-N970F przy użyciu Tapatalka
  11. #8
    Oct 2014
    България
    I don't think the problem is in the file. In my practice on this sprinter I always close the EGR and mechanically, this is necessary for problems with air mass.
