Write this file, everything should be fine.
I have Mercedes Sprinter W906 CDI EDC16CP31 someone tried to Remove DPF in wrong way, now the file has wrong checksum and many DTC,
please I need DPF OFF, correct checksum and remove all DTC.
Many thanks in advance.
<< KEEP LEARNING W.O LIMITS >>
2 Simple Methods To Say Thanks on DKPress Thanks _OR_ Add Rep
3inferno3 (7th June, 2020), konq100 (8th June, 2020), pinkfloyd5eg (6th June, 2020)
Thank you so much, I will try and report....
stanislav georgiev (6th June, 2020)
Thanks for your great work, the file worked like a charm, only the mechanic took it on a test drive and I am sure it will be fine.
I am sorry to bother again, but after the test drive the car shows this DTC code is 2671-002 monitoring function quantity injected, is it because of something in the ECU file or do you think this has nothing to do with the file and it is a mechanical problem !!
The file is fine, I've done a lot of sprinters, I'll check the error code on Monday.
Adjust injector zero quality with diagnostic tool and will be fine.
Wysłane z mojego SM-N970F przy użyciu Tapatalka
I don't think the problem is in the file. In my practice on this sprinter I always close the EGR and mechanically, this is necessary for problems with air mass.
