Results 1 to 5 of 5
    Nov 2019
    Default Astra J 1.4 delco e83 ecu
    Hi does anyone know if its possible to clone a ecu from a astra J 1.4 delco e83 ecu
    No eeprom listed with ktag so wondering if it's a virtual eeprom of so what are my options
    Is the mpc enough to make the car start?
    rafal's Avatar
    UK - PL
    pin stored in MPC..................rest job by obd
    or Io terminal will help to do all by obd
    need help
    now my goal is to buy xp-005
    who will help?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Bennettj3 View Post
    ioterminal cover a lot of GM/Opel Delco units without opening...
    but also a cheaper and also safe way is russian MD Flasher on this E83, also without opening...
  4. The Following User Says Thank You to figani For This Useful Post:
    Bennettj3 (6th June, 2020)
    Nov 2019
    Hi thanks I've been looking at md flasher can this be used on the bench or can it be use with a universal tricore / boot cable aswell
    figani's Avatar
    Feb 2018
    You can connect it on bench with Scanmatic for example but also other HW direct by pinout...
    In ioterminal you have pinout, just check site...
  7. The Following User Says Thank You to figani For This Useful Post:
    Bennettj3 (7th June, 2020)
