Passat 2.0 cffb edc17c46
Results 1 to 11 of 11
    Apr 2017
    Oslo
    11
    Default Passat 2.0 cffb edc17c46
    Hi.
    To clone immo I need old and new ecu's files and Immo universal decoding right? Ktag files attached. Can anyone help? Old ecu has ori maps, new one has tuned maps and immo off.
    Sep 2014
    Guildford UK
    9
    Bad read of the ECU as immo ID not showing,
  3. The Following User Says Thank You to jacek77 For This Useful Post:
    surdyka (9th June, 2020)
    rob h's Avatar
    May 2011
    923
    new adapted.rar Here you go, write eeprom only to new ecu.
  5. The Following User Says Thank You to rob h For This Useful Post:
  6. #4
    13
    Default EDC17C46 NEED IMMO PIN
    hello
    i need immo pin just did a ecu swap,having problem need immo pin code to programme key,please can you help me
    these files are old ecu
    ricked's Avatar
    Apr 2016
    Europe
    69
    Quote Originally Posted by playa786 View Post
    hello
    stop spamming dude
  8. #6
    13
    im not spamming mate i need help with file im stuck
  9. #7
    Oct 2016
    Slovakia
    34
    ECU_MODEL=EDC17C46
    VIN=WVWZZZ7NZBV040068
    IMMO_ID=
    CS=125C6FB50DB900
    PIN=54782
    MAC=3B9524C6
  10. The Following User Says Thank You to jokir For This Useful Post:
    playa786 (2nd August, 2020)
  11. #8
    13
    thank you mate,will let u know if it worked
  12. #9
    brend's Avatar
    Oct 2015
    Same where
    2,312
    For future if you still wan't help in here!!!
    For thanks use this option...........Thanks+rep..jpg..........and more active in DK!
    About information for ask ...........
    http://www.digital-kaos.co.uk/forums/announcement.php?f=174&a=32
    First read rules ........................
  13. The Following User Says Thank You to brend For This Useful Post:
    playa786 (1st August, 2020)
  14. #10
    13
    pin code worked forold ecu im greafull,if you could help me with new ecu pin will be very happy,will use the button below as you suggested,
    new ecu file skc or immo pin required
  15. #11
    13
    no my friend it did not work
