Results 1 to 10 of 10
    Default VW T5.1 dash swap problem 7E0920 970N
    Trying to fit a replacement dash with temp and fuel guages to a vehicle that has a lowline dash .
    Replacement dash wont program due to eeprom checksum errors ,not sure whats been done before it came to me.
    Is this recoverable or is dash scrap.
    7E0920 970N
    mixauto's Avatar
    Ukraina Kharkov
    Try this but other errors may be present.
  3. The Following User Says Thank You to mixauto For This Useful Post:
    r6eck (9th June, 2020)
    Thanks for your help mixauto, still have checksum error .
    Anyone else got a solution, or is it possible to use another dump?
    Oct 2016
    Slovakia
    Try and report
    pass DK
    No password recieved
    Sent from my SM-N960F using Tapatalk
    Romania
    what do you mean by "Replacement dash wont program due to eeprom checksum errors" ? Explain please how did you tried.
    I have tried with Odis ,it fails with an error that dash is faulty or not compatible.
    When checking with odis or vcds it gives check sum errors.
    I've tried eeprom prep with smok, still gives no access to read Skey.
  10. #9
    Romania
    In ori eep, put FF from 12c0 to 145F and write this damaged eep to dash. Then try smok by obd to acces dash. If acces is ok write by obd original eep and then edit or load ori security block from original working dash.
  11. #10
    Quote Originally Posted by ghitab View Post
    Tried that, same result "security access error 61"
