Results 1 to 12 of 12
    May 2020
    Default rns510 columbus boot loop
    Hi, i have a Rns510 Columbus 3T0 035 680 A HW H41 SW 2724. Problem is its not loading, its just showing skoda logo and rebots after a cople of second. tried the recovery cd but didnt work and setup + eject+mic just reset the unit but there is no meniu for loading the cd software.
    Help
    May 2020
    No one ? Nothing ? If I keep pressed for 30 sec on setup eject and microphone it should appear a" load swl " message?
    Portugal
    hello .
    I go through a link where you can have the firmware and how to do the procedure.
    http://www.my-gti.com/1986/volkswage...-boot-problems
    May 2020
    Thanks rui, I tried but it's doing nothing I have to eject the CD manually , I think I need to rewrite the dump memory and at the moment I can't find it anywhere.
    Oct 2018
    Quote Originally Posted by tester212 View Post
    hw41sw2720
  6. The Following 2 Users Say Thank You to Mikle1 For This Useful Post:
    darekpola (8th November, 2023), vavrich (5th November, 2020)
    Apr 2017
    If no failed software update,Try to resolder big flash. i,m not remember if is f400 or 800.
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    Quote Originally Posted by Abcparty View Post
    it`s wrong way.
    May 2020
    Sorry for not replaying but... well life happened . dec123ua why its a wrong way ? help me out here please.
  10. #9
    Oct 2018
    if there are problems with the bootloader ,need desolder and reflash only s29Al016 , no need more ,also maybe you have problem with NAND ,if you have setconfig cable you can erase it.
  11. #10
    May 2020
    i have a cable but no software ... so no way out. So my only option is to desolder the s29 chip and reflash it with the soft from Mikle1 (btw thanks man )
  12. #11
    Oct 2018
    you can erase nand in the programmer too
  13. #12
    Dec 2015
    I don't know if I did everything but the dump doesn't work. Mainly I think it's not H41 but H04 can you confirm that?
