Results 1 to 5 of 5
    Nov 2019
    Default Ford mondeo delphi dcm 3.5
    hi could any help check to see if this immo reading from eeprom 95640 is ok from a mk4 mondeo delphi dcm 3.5.
    the car wont start with immo light flashing bcm has been checked and all ok .
    ecu its self seems fine so just need to make sure eeprom is ok
    many thanks
    rafal's Avatar
    UK - PL
    can you tell me what is .mpj file ?
    need help
    now my goal is to buy xp-005
    who will help?
    Nov 2017
    hello please i need full bdm ktag for delphi dcm 3.5 mondeo mk4 . hw bg91-12a650-se , sw bg91-14c204-ffd . thank you
    Nov 2019
    It's what my reader saves the file has I forgot to change the read to. Bin
    Nov 2019
    Hi I've done a eeprom swap on this ECU but car will not start checked with scanner and I've attached fault codes in pictures
