Results 1 to 12 of 12
    Nov 2010
    Default Cas1 E65 61.32-6942 487
    After try done this cas1 E65 with DigiProg via OBD it was dead.
    Someone can see if possible if problem is eeprom or flash?
    ricked's Avatar
    Apr 2016
    Europe
    did you try to reset CAS and/or cluster?
  3. The Following User Says Thank You to ricked For This Useful Post:
    Repinator (14th June, 2020)
    waldi1979's Avatar
    Dec 2010
    Try this EEP.
    Your file looks strange (size).
    Your PM is full.
  5. The Following 2 Users Say Thank You to waldi1979 For This Useful Post:
    p1et (20th June, 2020), Repinator (14th June, 2020)
  6. #4
    Nov 2010
    Quote Originally Posted by waldi1979 View Post
    Try this EEP.
    Your PM is full.
    now the indbox is empty
    I read with Smok JTAG,I think it reads OK
    the car is 100km away, I will try the eeprom tomorrow.
    Nov 2010
    Quote Originally Posted by ricked View Post
    I disassembled the plus terminal,it is enough?
  8. #6
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by Repinator View Post
    the question was: what did you try to do? reset CAS km/mileage ??
  9. #7
    Nov 2010
    Yes,that was tried
    The cluster was not touched,only CAS with DigiProg via OBD
  10. #8
    brend's Avatar
    Oct 2015
    Same where
    Why ask the same stupid question...dash or cas...?
    Where you saw that ,E65 dash can be reset obd2 away?
    E65 dash reset km obd2 away impossible !
    Even if you kill dash, the car will not die, started and drive on without dash.........
  11. #9
    Nov 2010
    The cluster It's ok ,only CAS1 broken with DigiProg via OBD
  12. #10
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by brend View Post
    for the SIMPLE FACT that they dont ALWAYS TELL EVERYTHING what they do, i dont have crystal ball like you
    so keep your useless comments to yourself
  13. #11
    brend's Avatar
    Oct 2015
    Same where
    Check transport mode function in cas ,maybe it's just stay sleep mode after set.
    No!
    I have a magic wand from Harry Potter and a powder.......
  14. #12
    Nov 2010
    @waldi1979
    Thank you very much
    He came back to life
  15. The Following User Says Thank You to Repinator For This Useful Post:
