Results 1 to 9 of 9
    marsete's Avatar
    Oct 2010
    SPAIN
    Default I NEED PIN CODE FOR SAAB 93 TID
    Hello friends,is posible pin code in eeprom ecu?ecu is edc16c9,i read with ktag.i need pin code for recode key.Thanks and regards
    rafal's Avatar
    UK - PL
    9IC6 .............................
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    marsete (15th June, 2020)
    marsete's Avatar
    Oct 2010
    SPAIN
    Thanks Rafal for your fast response...
    marsete's Avatar
    Oct 2010
    SPAIN
    Hello rafal...pin not work...in module cim??
    rafal's Avatar
    UK - PL
    strange.........should work
    need help
    who will help?
  7. The Following User Says Thank You to rafal For This Useful Post:
    marsete (18th June, 2020)
  8. #6
    marsete's Avatar
    Oct 2010
    SPAIN
    thanks rafal...yes is strange,i read module cim and compare...very thanks friend
  9. #7
    marsete's Avatar
    Oct 2010
    SPAIN
    Rafal please i need reprogram key other saab...is posible pin code in chassis number?? YS3FF51P391005274.Thanks
  10. #8
    marsete's Avatar
    Oct 2010
    SPAIN
    hello...rafal your code is correct...thanks
  11. The Following User Says Thank You to marsete For This Useful Post:
    rafal (18th June, 2020)
  12. #9
    Aug 2010
    Hi can someone provide pin for this saab 9-3 vin : Ys3fh41p881132735
