Results 1 to 7 of 7
    Nov 2019
    Belgium
    Default UPA-USB Test 5 and 7 failed
    Hi, I tried to read an MC68HC05B16 with the adapter 14 but it did not work.
    The hardware test gives me failed on 5 and 7, someone with an idea?
    BR
    UPA-USB Device Programmer v13014
    Licensed to: Xinbo Zhang
    System: Microsoft Windows 7 Ultimate Edition Service Pack 1 (build7601), 32-bit
    Detecting UUSP...Pease wailt!
    Device Description: ELRASOFT UPA-USB3.0 Driver (1.2.2.00, 12/20/2012)
    USB Driver Name: UPAUSB.sys, HS Mode
    5V Tests. Close J1 and press a key to continue
    Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=7,91V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=8,99V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=9,85V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=10,65V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    P1(10,65V ) not in 10,70V - 11,30V
    Test Failed
    Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=11,75V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    Test Passed
    Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Result: P1=12,65V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
    P1(12,65V ) not in 12,70V - 13,30V
    Test Failed
    Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
    Result: P1=0,00V, P2=3,98V (L), P3=0,00V (L), P4=0,00V (L),P6=4,00V (L), P7=0,00V (L), P8=0,00V (L), P9=4,85V
    Test Passed
    Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
    Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,83V
    Test Passed
    Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
    Result: P1=0,00V, P2=4,82V (H), P3=4,82V (H), P4=4,83V (H),P6=4,85V (H), P7=4,83V (H), P8=4,85V (H), P9=4,85V
    Test Passed
    3.3V Tests. Open J1 and press a key to continue
    Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
    Result: P1=0,00V, P2=2,90V (H), P3=0,00V (H), P4=0,00V (H),P6=2,92V (H), P7=0,00V (H), P8=0,00V (H), P9=3,43V
    Test Passed
    Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
    Result: P1=0,00V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,03V (L), P7=0,00V (L), P8=0,00V (L), P9=3,42V
    Test Passed
    Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
    Result: P1=0,00V, P2=3,40V (H), P3=3,40V (H), P4=3,42V (H),P6=3,42V (H), P7=3,42V (H), P8=3,42V (H), P9=3,42V
    Test Passed
    Test60
    9544961E0447E012
    Test Passed
    2 Tests failed
    Nov 2019
    Belgium
    Hi, reading ok with upa and adapter 14, but I still have test failed for 7 and 5...
    Nothing to worry. You see that on Test5 P1 is just 0.05v too low and the same thing to Test7.
    But if you want, try to slightly increase output voltage of an internal regulator, I think that would help.
  4. The Following User Says Thank You to Zmann For This Useful Post:
    Koom (16th June, 2020)
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Or use better usb cable. Mine was bugging and a new good cable and now it is ok.
  6. The Following 2 Users Say Thank You to PSAcars For This Useful Post:
    Koom (16th June, 2020), Zmann (16th June, 2020)
    Nov 2019
    Belgium
    Quote Originally Posted by Zmann View Post
    merci mon ami, si ce n'est grave je laisse comme ça, il fonctionne bien pour l'instant. encore merci!
    Envoyé de mon iPhone en utilisant Tapatalk
  8. #6
    Nov 2019
    Belgium
    thank you my friend, if not serious I leave like this, it works well for now. thanks again!
  9. #7
    May 2020
  10. The Following User Says Thank You to Nesi Aleksic For This Useful Post:
