Results 1 to 4 of 4
    Mar 2019
    Earth
    Default GOLF 5 VDO MICRONAS 24C32 PIN CODE
    Hi guys.I work on a 2008 VW GOLF with faulty Dash.I ve managed to read immo content with FVDI but for some reason i cannot write it back to donor cluster,after some research i ve seen that i need to put them in service mode and try again,and also fvdi isn t the best tool for this job.
    Now i want to try to manually adapt it with VCDS by pincode.
    Here you have the 24c32 eep read by vvdi prog of the donor cluster.
    can anyone be gentle and tell me the pin code?
    neksus's Avatar
    Jun 2013
    Quote Originally Posted by 12manux View Post
    Look here...
    https://www.digital-kaos.co.uk/forum...00#post3049700
    PRESS THANK + REPUTATION
  3. The Following User Says Thank You to neksus For This Useful Post:
    serikpay (27th March, 2023)
    tepSIJA's Avatar
    Dec 2015
    OTP
    Read flash and eeprom for pincode
    Tempus Omnia Revelat
    Mar 2019
    Earth
    Solved
    I wrote new dump with service mode into new cluster and uploaded eeprom and immo data of old dash,car started.
    thanks all
  6. The Following User Says Thank You to 12manux For This Useful Post:
    jomberykaso (18th June, 2020)
