Results 1 to 13 of 13
    Jan 2010
    Default W176 FBS3 or FBS4?
    Hi lads
    Is there any way to check which version is in 2014 w176 by the vin number? FBS3 or FBS4
    WDD1760122J118678
    Thanks in advance for help
    This is EIS part no. A246 905 98 00. Maybe someone else know what it is.
  3. The Following User Says Thank You to qwojtus For This Useful Post:
    cheester (17th June, 2020)
    Oct 2011
    Planet Earth
    I think car is 2013MY. So , it's a fbs3. roi
    Quote Originally Posted by cheester View Post
    Hi lads
    WDD1760122J118678
    Mar 2018
    Car is 2013-May
    Year of manufacture indicated is 12/1
    It is from 2012 product line, so it is still FBS3.
  6. The Following User Says Thank You to babeh For This Useful Post:
    cheester (18th June, 2020)
  7. #5
    pepi's Avatar
    Jan 2010
    It will be writen on EZS label if FBS4.
  8. The Following 2 Users Say Thank You to pepi For This Useful Post:
    autodiagdoctor (20th June, 2020), kwat (6th December, 2023)
  9. #6
    Jan 2010
    Quote Originally Posted by pepi View Post
    Have a two in garage and non of them are signed like yours one.
  10. #7
    Jan 2010
    Anyway I got the key reading and its FBS4
    Is there any solution to fix esl or use emulator?
    Or only merc dealer is the option?
  11. #8
    Apr 2016
    what tool did you use? both should be fbs3 system
  12. #9
    Jan 2010
    Was told the very same by friend of mine when he saw the labels only but when he connected ezs and key he said its a new system fbs4. Not sure what tools he used.
  13. #10
    Jan 2010
    Its FBS4 100%, is there any solution for this or only dealer?
  14. #11
    fred77's Avatar
    Jun 2019
    If FSB4 then no -haven't heard any solution yet.
    Did you try pluggin in and reading ESL as won't hurt.
    I know no steering lock throw me at 1st but did a key still - worth a try
  15. The Following 2 Users Say Thank You to fred77 For This Useful Post:
    cheester (23rd June, 2020), kwat (6th December, 2023)
  16. #12
    Mar 2018
    Maybe my previous message is misleaded.
    what's pity it moved to FBS4
  17. The Following User Says Thank You to babeh For This Useful Post:
  18. #13
    Nov 2017
    London, England.
    Easy way to check is to check Datacard or the actual part on EPC it will show the FBS4 code if it is which is A17 I think.
