Results 1 to 10 of 10
    Default NEED DISPLAY SAFE OPEL ASTRA 2005. HERE IS DISPLAY AND RADIO EEPROM
    HELLO. NEED DISPLAY SAFE OPEL ASTRA 2005. HERE IS DISPLAY AND RADIO EEPROM. CD30MP3
    Bulgaria
    Quote Originally Posted by goranradovicpg View Post
    Hi, try this file for cd30......
    And use code from display 1888 for marriage!
  3. The Following 5 Users Say Thank You to bogege For This Useful Post:
    criollo (17th June, 2020), irfa (17th June, 2020), murat332 (18th June, 2020), nihadbeg (21st June, 2020), shooting (17th June, 2020)
    THANKS MY FRIEND BUT NOW WRITE RADIO SAFE AND TEN SECOND HEAR BEEP
    WALES
    Because you need to PAIR device with your OBDII tool...
    wbr
  6. The Following 2 Users Say Thank You to shooting For This Useful Post:
    criollo (17th June, 2020), murat332 (18th June, 2020)
    HOW? I TRY WITH OPCOM ACTIVATE ANTI TREFT. WRITE SUCCES BUT AGAIN SAME THING. THE DISPLAY CODE IS 1888 AND I WRITE THIS CODE.
  8. #6
    ON THE RADIO SAY
    THEFT PROTECTION DELIVERY STATE
    SECURITY WAIT TIME NOT RUNNING
    REMAINING SECURITY CODE INPUT 10
    I CHECK MIDLE CONFIGURATION ALL OK
  9. #7
    Aug 2014
    ON THE RADIO SAY
    Enter EHU....Programming.....Activate Theft Protection.....when ask the code enter 1888 and hit OK. MID Speed CanBus must be the same in EHU and DIS
    All done
  10. #8
    I TRY. ALL OK AND AGAIN BEEP.I CHECK 50 TIMES BUT NO SUCCESS
  11. #9
    WALES
    Use this modified Display dump and pair Radio using 1888 using MID CAN
    (Make sure Radio had Virgin dump installed)
    wbr
  12. The Following 3 Users Say Thank You to shooting For This Useful Post:
    goranradovicpg (18th June, 2020), murat332 (18th June, 2020), nihadbeg (21st June, 2020)
  13. #10
    SHOOTING you are the best. Now all is okkk. THANKS
