    Oct 2019
    Default 2007 Dodge Ram 1500
    Hey Friends,
    Quick question, can anyone tell me if there is any option to do an IMMO off on a 2007 Dodge Ram 1500.
    I can't connect to the car to make a key with x100 pros, or autopropad, or smartpro. Maybe I can make a key to start the engine with vvdi prog, and vvdi2?
    Thanks,
    Randy
    Jan 2019
    Turn the key, if you seem immo light on dash, has skreem module around the ignition
    Sent from my Pixel 3 XL using Tapatalk
    Oct 2019
    any other solutions ?
    Jan 2019
    Quote Originally Posted by randyrash View Post
    I didn't realise you said immo off. Depends on the ECU it uses. What engine does it have?
    Oct 2019
    5.7 hemi..
    alex_r_2001's Avatar
    New Jersey ,, USA
    If you have cardaq j2534 you can unplug immo antenna and then use
    j2534 toolbox2 or j2534 toolbox3 to reset skim in ecu.. This deactivates immo in ecu.. Ive done many times with chrysler
    Also if you want to make key read mcu or eeprom and use vvdi 2 with superchip it makes dealer key.. no need to program with scanner once you are done.
