i m learning and editting some remapping files. And also ve questions about remapping. Detailed questions i ve. Who can answer me,truly..
Think you need to be more specific. A question regarding what?
I started learning to edit map.
you need turbo compressor map, once you have it you can use this calculator to see max mass air flow it can handle, what is surge and choke line
https://www.boosttown.com/forced_ind...calculator.php
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
adamhobbymaster (24th June, 2020)
here is just example to get basic understanding
example compressor map of GT1749V, now go to https://www.boosttown.com/forced_ind...calculator.php and enter parameters
engine rpm example 3000rpm
engine size example 2.0tdi 1968ccm
volumetric efficiency example 90%
boost pressure bar example 2 (this is absolute boost, without atmospheric 1 bar) !
Calculate
now you see in calculations Amount of air in lbs/min = 19.6885
go to compressor map and find on Y axis 19.7
and find on x axis boost bar
you can calculate on every rpm and pressure
Volumetric efficiency varies with rpm !
Keep in mind that for example 2bar on 2.0 engine is not same as 2bar 3.0 engine, thats why you can see flow
Could u calculate mine for me.
