Results 1 to 13 of 13
    Nov 2019
    Default Bmw edc17cp02 clone
    Hi I've tried to clone a ecu for a BMW EDC17CP02 with ktag did a full read and swapped over the to new ecu but when trying to sraty I get error code
    EWS anti-tampering protection"
    Any one help me out with this thanks
    sdnatlst's Avatar
    Aug 2011
    England
    you will need to sync DME and EWS using BMW diagnostic tool like ISTA D to resync the rolling immobiliser code together
    Tools owned -
    Nov 2019
    Hi would inpa work? Also been told has its edc17 re synch won't work is that true
    Aug 2015
    Germany
    Sync is for ews3 systems or older
    Esc17 has ews4 System and does sync automatically
    Recover donor ecu to original state
    Post ecu dump Original and donor
    And cas dump
    Nov 2019
    What's needed for ecu just eeprom dump?
    Apr 2016
    Quote Originally Posted by Bennettj3 View Post
    if second ecu is the same make immo off..
    Nov 2019
    Is immo just in eepeorm?
    Aug 2015
    Germany
    Dont know exactly where ISN was stored, habe to look in my notes. Just post whole content when I’m home I will take a look
    Immo off as far as I know is in Flash (but not sure)
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    1-Immo off is in flash
    2-you can change isn and put old isn to new used ecu
    3-you can put new used ecu's isn to cas-ews
    4-these new bmw ecu,cannot clone even if you read full,car wont start
    If i Helped you,use thanks and rep button to thank me back
    Nov 2019
    hi could you make immo off possible thanks
    Apr 2016
    [QUOTE = Bennettj3; 3899974] ciao, potresti rendere l'immo off possibile grazie [/ QUOTE]
    this is your immo off file, you must calculate chks
    pass pm after thnks + rep
    regards!
  12. The Following User Says Thank You to eculevel For This Useful Post:
    Bennettj3 (24th June, 2020)
  13. #12
    Nov 2019
    Thanked and added rep
  14. #13
    Nov 2019
    Quote Originally Posted by eculevel View Post
    regards!
    Hi could you send pass please
