Results 1 to 11 of 11
Thread: Z16XE sluggish
    Jan 2019
    Default Z16XE sluggish
    Hi,I have z16xe, I have errors and I think is ECU, it is not responsive sometimes to acc pedal, sluggish a lot, it starts good. Egr is clean, I erase dtcs and I get missfire on cylinder 1. I will order spark plugs and coil.
    racin-snake's Avatar
    Jun 2009
    Take out the pre cat 02 sensor see if misfire has caused the cat to melt and block
    also check on live data on opcom see if the ACC pedal is responding in the ECU and TB
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Jan 2019
    ACC pedal is working.,
    Jan 2019
    Why you told me the catalytic converter is blocked or melted ?
    Meat-Head's Avatar
    Quote Originally Posted by Andr33iy98 View Post
    Having such a low number of DK thanks will cause a weak mixture, this weak mixture
    causes the engine to overheat melting the cat
    could also be running rich so remove lamda sensor and check
    #black lamda sensor too much fuel
    #white lamda sensor not enough fuel
    find me an areoplane to drag them from
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    racin-snake (30th June, 2020)
  7. #6
    Jun 2009
    I didnt I asked you to check if it was TRY READING THE POST
    Quote Originally Posted by racin-snake View Post
    "Take out the pre cat 02 sensor to SEE if misfire has caused cat to melt and block "
  8. #7
    Jan 2019
    Can I reflash egr off with carprog 8.21 ? Save a bin file and edit, and put it back with egr off exe ?
  9. #8
    Meat-Head's Avatar
    This “flashing” stuff you have to be aware you can kill an ecu
    so do that as last resort
  10. #9
    Jan 2019
    I DO NOT care about killing
  11. #10
    Meat-Head's Avatar
    Well just swap the engine then
    https://m.youtube.com/watch?v=yLwtsLt1H-c
  12. #11
    Jan 2020
    SImple trick... start the engine... disconnect the egr.... get in to the car.... an press the gas pedal. Is there an difference ? More powerfull? Than its the egr.
    If its running worse or still has misfire it has nothing to do with the egr. I would say it's your coil and or your o2 sensor. Because real misfire happens mostly only if you have some failing ignitions. all other things like to lean or to rich do not cause heavy misfire in idle... flashing your ecu will not get you to an final solution. Because even its flashed... why should then the problems stop`? problems with egr are more during driving... or the engine dies as soon as you press clutch etc...
    but misfire etc shows clearly problems in your ignition and o2 system. Check it with op-com... turn on the graphs. the o2 sensor should always go up and down from 0.100V - about 0.800V sometime like an sinus wave.... if its broken it just does "something" and the graph does not make sense
