Mazda CX-7 2.2 MZR
Results 1 to 9 of 9
    Default Mazda CX-7 2.2 MZR
    is here any expert that can help me with the Mazda CX-7 to just switch the adblue off?
    One year ago, I flashed the SCR off file into the car but now the dpf ligt in the dash is blinking.
    Can someone please check if the file is good and only SCR off? If not, I would be very happy if someone can help me!
    Thank you!
    Jun 2019
    hi,i saw that you have the same file like i do.i have already a modified file adblue of only,and its working very well for my car
    pike's Avatar
    Sep 2013
    and no DTC's?
    it's because some DPF errors disabled in your file
    Jun 2019
    Default mazda cx7
    ok,my friend ,here is your file.disconnect adblue from under the driver seat and scr fuse.thanks and rep
  5. The Following User Says Thank You to boby1979 For This Useful Post:
    golfV (24th June, 2020)
    Jun 2019
    And after writing the file make sure to erase all dtcs and for blinking dpf try to reset oil interval.
    Okay I will try to! Which tool did you use to reset oil interval?
    Thank you for your help! :-)
    Jun 2019
    forscan ,you can register and downlod it from the original site ,and you will be able to activate the program.its all free
    Hi boby,
    I got forscan and flashed your file!
    Now I have DCT P1336 crankshaft/camshaft error. I think thats the reason why the DPF light is blinking...
    Can you help me to disable the DCT and light? Car is too old to fix it. But seems as SCR off is working great :-)
    Thank you for your help!!
  10. #9
    Feb 2020
    P1336 = your timing chain is stretched.
