Results 1 to 15 of 15
    Feb 2012
    Default NEW PROBLEM with vw passat b6 edc17
    Hello, can someone calculate pin and cs for passat b6 from confort module EEPROM 95320. Thanks in advance
    rafal's Avatar
    Jul 2010
    UK - PL
    bad readed.....................
    need help
    now my goal is to buy xp-005
    who will help?
    RG550's Avatar
    Oct 2017
    Dump is not ok, read it again.
    Feb 2012
    readed with upa as 95320
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by alkazav View Post
    and ????????????????????????
    need help
    who will help?
    Feb 2012
    See now, please
    Jul 2019
    CS: 1448E2342891C4
    Pin: 19927
  8. The Following 2 Users Say Thank You to immoneard For This Useful Post:
    alkazav (25th June, 2020), yugo45 (20th August, 2020)
  9. #8
    rafal's Avatar
    Jul 2010
    UK - PL
    now is ok..................
    VIN: WVWZZZ3CZ8P120587
    Immo ID: VWZCZ000000000
    CS: 1448E2342891C4
    MAC: 13F8656C
    PIN: 19927
    Power Class: FE
    ELV: 17DC
    CCM Status: 6
    Key Count: 2
    Key1: D74F2C6D
    Key2: A6713AB1
    Hardware version: HLOW4203040800042000P0041627
    VAG Part Number: 3C0959433R
    Software version: 0472
    need help
    who will help?
  10. The Following 3 Users Say Thank You to rafal For This Useful Post:
    alkazav (25th June, 2020), lion0304 (25th June, 2020), yugo45 (20th August, 2020)
  11. #9
    Feb 2012
    Thanks both, immoneard and rafal
  12. #10
    Feb 2012
    I need help again with this car. I replace old broken ecu with new used one. i can read both eeporm and mpc with ktag from both ecu. I do immo of in donor ecu and car start but show error on table and error dtc in engine module. How can I solve this? I tryed to add key again but without sucess
  13. #11
    dimon9555's Avatar
    Oct 2012
    Belarus
    Everything is very simple, you need to adapt the ecu to the car)))
  14. #12
    Feb 2012
    how? tell me if so simple
  15. #13
    ricked's Avatar
    Apr 2016
    Europe
    magic answer will be "online"
  16. #14
    dimon9555's Avatar
    Oct 2012
    Belarus
    A normal person if he wants to adapt two blocks, then he loads dumps from two blocks
  17. #15
    Jul 2019
    Because you doing immo off wrong way. With correct Immo off no error in dash.
